Silksong Guide: How to Get the Scuttlebrace Tool a
Find Hollow Knight Silksong’s Scuttlebrace in the Twelfth Architect’s Workshop and unlock Hornet’s rapid retreat.
In the expansive world of Hollow Knight: Silksong, players must explore every corner to find powerful tools that aid Hornet in her journey. One such tool, the Scuttlebrace, is a unique yellow tool that grants a rapid retreat ability, mimicking the movement of a spider. Available in the second Act, this tool can be a game-changer for those who master its mechanics. As of 2026, this guide remains accurate for players diving into Silksong’s second Act. Here is a comprehensive breakdown of how to obtain the Scuttlebrace and what it does.
Location and Acquisition
The Scuttlebrace is found in the Twelfth Architect’s Workshop, located in the Underworks. To reach it, players must first progress through the second Act and obtain the Clawline ability. Here is a step-by-step breakdown:
Reach the Citadel: After making your way through the Underworks, you will arrive in the Citadel. Head towards the left side of the map.
Find the Elevator: Locate the elevator that requires the White Key. Before using it, make your way to the top right part of the map, called Songclave.
Get the White Key: In Songclave, you will find the White Key and can ring the bell inside the First Shrine. This turns Songclave into a hub for NPCs and quest givers.
Descend to Whiteward: Return to the elevator and go down to reach Whiteward. Follow the main story path, which leads you to the eastern side of the Underworks to find the Clawline ability.
Return to the Underworks Bench: Once you have Clawline, make your way back to the bench in the Underworks. There, you will hear an NPC talking.
Reach the Workshop: Jump up and harpoon the grapple point, then dash right to enter the Twelfth Architect’s Workshop.
Purchase the Tool: Talk to the NPC inside and purchase the Scuttlebrace for 140 Rosaries and 1 Craftmetal.
What Does the Scuttlebrace Do?
The Scuttlebrace is a yellow tool that enables Hornet to perform a rapid retreat, similar to a spider’s scuttle. This maneuver is not just a simple dodge; it offers significant mobility advantages. When activated, Hornet can quickly move backward or in the direction she is facing, covering a considerable distance. Moreover, by holding down the button, Hornet can even walk on walls in this stance, allowing access to otherwise unreachable areas.
Controls:
Controller: Press RT/R2.
Keyboard: Press Down + C.
Tips for Using the Scuttlebrace
Exploration: Use the Scuttlebrace to reach hidden ledges and secret areas by scuttling up walls.
Combat: Quickly retreat from enemy attacks, especially bosses with fast lunges.
Platforming: Combine with Clawline and other movement abilities for advanced traversal.
Stamina Management: The Scuttlebrace does not consume Silk, so it can be used liberally.
Acquisition Summary
Detail
Information
Tool Type
Yellow
Location
Twelfth Architect’s Workshop, Underworks
Cost
140 Rosaries + 1 Craftmetal
Prerequisite
Clawline ability, Act 2
Ability
Rapid retreat, wall walk
Conclusion
The Scuttlebrace is an essential tool for any player looking to enhance Hornet’s mobility in Hollow Knight: Silksong. Its unique spider-like retreat opens up new avenues for exploration and combat. By following the steps outlined above, you can add this versatile tool to your arsenal and truly master the art of the scuttle. Whether you’re dodging attacks or scaling walls, the Scuttlebrace is a worthy investment for your journey through the Citadel and beyond.
Once you’ve mastered the Scuttlebrace and are ready to see what else the genre has to offer, keeping an eye on your gaming budget can be just as useful as nailing a wall-scuttle. Whether you’re waiting for a discount on Hollow Knight: Silksong itself or hunting for your next Metroidvania fix, a reliable [steam deal finder]( can help you spot price drops without refreshing store pages manually.
DealNest is built for exactly that kind of browsing, gathering current Steam discounts in one place so you can compare and decide when to buy. It won’t teach you Hornet’s controls, but it can make expanding your library after Pharloom a little easier on the wallet.
